Instrument Cluster Circuit Board is Bad! $1000 bucks!!!
#376
So I tried to fix this myself. Was able to solder things fine. However when I soldered c212 I didn't put it in an angle and when I tried to put the cover back on it seems I ripped the cap and the contacts out, as you can see in the picture. Anybody have any ideas on how to fix this giant f*#@ up.
I am going to the junkyard this weekend and hope I can find a 93/94 with the cluster still in it.
#377
I believe I have the same problem, however , mine does it when its cold or warm. The whole guage cluster flickers on and off sometimes when i hit a bump, they will come on and then go off again. Last night i had to drive it and the cluster didn't light up at all. I've read the sticky's on this problem but very unaware of what to do first. I know how to solider and desolider,things like that, but I have no earthly idea of what I'm looking for.. Should it be something as easy as a loose connector?
#378
PM if you wish to discuss one I have...
#379
i recently bought a 1993 ls400 that had been sitting a long time [8years]. the caps in the ECU where bad, causing it to not shift. with the caps in the ECU the car runs great and tranny shifts like it should. the cluster is partially working. the needles light up correctly, indicators all seem to work.
i changed out 3 caps [c212 c147 c142] so far, but have not fixed any of problems i am experiencing with the gauges...
this is what does not work/issues:
fuel gauge is at empty, light is on
speedometer is not working [and O/D flashes codes says Vehicle speed sensor 1]
backlighting is not working [ cannot see numbers]
which caps would you folks suggest i change out next? if i could see numbers that would be great
i also wanted to say thanks for all the information in these threads! if anyone needs help in tucson,az i am glad to help.
#380
I visited Tanin Electronix (they spell it with an x) and delivered an instrument cluster for basic repair..along with cores they expressed interest in purchasing...
I have a background in electonic components and materials; Automtive instrument cluster OEM's Stewart -Warner, Motorola, Littelfuse (fuses), Autometer, were but a few of accounts I serviced.
I am contemplating a write up of my experience with Tanin, however thus far the experience has been unfavorable;
1.) Their advertising turn around time (1-3 days) is inaccurate and almost 2 weeks now do not have an answer.
2.) They have not kept their word to call me neccesitating I call them to follow-up on status.and can never seem to pin them down on a delivery date
3.) I was informed they are backlogged and short personnel and that yet the owner remains "out of town"
4.).I had to request a receipt listing the cores I delivered.
When I have a customer that requires attention I am 24/7...in fact I had two ECU's that the owner's needed the next day and was up until 3 AM to keep my word. (As a favor)
As an aside...I am looking to place my Negative grounding cable design wirh a distributor using Parts from Quick Cable who is 10 minutes drive from Tanin...
I posited to Tanin they could offer this, but instead no one there coukd be bothered to either see me or provide courtesy follow-up to understand the opportunity.
Right now I cannot recommend anyone to Tanin.
In fact am seeking alternates....
Anyone with recommendations?
#381
I realize this is an old thread but thought I'd check to see if you ever got an answer. I have the same issue, 1994 LS400, same symptoms, also replaced c212, c147, c142, but symptoms persist. Any help you can give would be useful. Thanks!
#382
http://www.taninautoelectronix.com/1...ter_repair.htm
__________________
TANIN AUTO ELECTRONIX
262-456-4147
contact@taninauto.com
262-456-4147
#383
Im having the same issue with the speed sensor, I don't know if fixing ALL the caps will fix it or if the issue is between the speed sensor and the actual cluster.
#384
Clusters at LKQ pickaPart are 25-35 dollars and extended warranty only 10-15 dollars. I bet most other places must be close.
#385
As long as the board does not contain any ASIC, it may be repairable by experienced electronics tech.
