Gas mileage?
Old 01-05-09, 09:40 AM
spazzy67
spazzy67's Avatar
Default Gas mileage?
My 91 LS400 w/ 175k miles is getting horrible gas mileage (13-15 mpg) & my exhaust smells herendous. Would changing my oxygen sensors increase mpg & if so, how many sensors does this year have & where are they located?
Also, my rear end is leaking. Could this be a gasket or a seal on the rear differential? easy fix?
Thanks you in advance for any suggestions.
Paul
Old 01-05-09, 10:08 AM
LiCelsior
Retired
LiCelsior's Avatar
www.lexls.com is the site for you, shows u how many o2 sensors there are, and how to read codes. u must have a CEL code.
rear end leak could be many things but maybe search in this forum and see if anyone had the same problem as you.
Old 01-06-09, 11:17 AM
EastWind
EastWind's Avatar
when was the last time it had spark plug wires/spark plugs changed, air filter changed? i don't see any reason to change oxygen sensor if it is not giving you a check engine light with a code suggesting to change them, i would do basic maintenance first. air filter, spark plugs/wires.
Enano
22
05-14-16 05:23 PM
SpencerT
33
01-05-13 05:12 AM
defo
RX - 1st Gen (1999-2003)
06-26-12 11:58 AM
MrFuel
41
01-09-12 03:56 PM
Bali26
11-10-07 01:32 AM
Quick Reply: Gas mileage?
