replace timing belt 96 after break
Old 01-27-09 | 07:55 PM
leboyd1's Avatar
leboyd1
Default replace timing belt 96 after break
A friend of mine didn't replace his timing belt, which broke.
Since it is a non-interference engine, i'm pretty sure there is no engine damage (which we will check).
Assuming no engine damage, to replace the timing belt shouldn't we align the cams to TDC and the crank to point to the #2 idle pulley, then mount the belt.
It seems with this plan, the cams and the crank will be set properly and then putting the belt on is just the step to keep them in sync.
Good plan, bad plan?
TIA
Old 01-27-09 | 08:02 PM
LiCelsior's Avatar
LiCelsior
Retired
CL Folding 500000
96 is interference motor...90-94 is not.
Old 01-27-09 | 08:12 PM
PureDrifter's Avatar
PureDrifter
BahHumBug
CL Folding 100000
yeah, 96 is an interference motor, and if somehow nothing broke you have the luckiest friend in the world. quick, take him to vegas/horse races/7-11 for lotto tickets/macau/etc.. immediately.
Old 01-27-09 | 08:19 PM
LiCelsior's Avatar
LiCelsior
Retired
CL Folding 500000
lol...but if ur not lucky. that engine is fubar'd.
Old 01-27-09 | 08:27 PM
JBrewster's Avatar
JBrewster
so, how many miles were on the belt when it let go?
inquiring minds want to know.
Old 01-28-09 | 08:03 AM
leboyd1's Avatar
leboyd1
140k
Come to find out it is a 99, not 96. Is this a non-interference engine?
Old 01-28-09 | 08:05 AM
LiCelsior's Avatar
LiCelsior
Retired
CL Folding 500000
90-94 is non interference....if 96 is, then that means all 95+ engines are interference motors.
Old 01-28-09 | 08:09 AM
leboyd1's Avatar
leboyd1
Okay, so he may be hosed.
I'll remove the top and take a look at the damage.
Just out of curiousity, when (and if) we get this motor back together or replace it, would setting the timing be as I originally asked?
TIA
Old 01-28-09 | 10:50 AM
PureDrifter
BahHumBug
CL Folding 100000
95-97 and 98-00 are both Interference motors. if it was a 99 most definitely its going to have SOME damage at least.
can't remember but i'll check over my manual tonight/tomorrow for you.
Old 01-28-09 | 02:26 PM
damon's Avatar
damon
Would the damage be confined to just the cylinder heads when a belt breaks on an interference engine??
Just curious, I am a non-interference owner.
Old 01-28-09 | 02:40 PM
PureDrifter
BahHumBug
CL Folding 100000
the valves, seals, guides, and possibly more would be toast
As would the piston and cylinder wall it hit
Old 01-29-09 | 12:54 AM
Broker404's Avatar
Broker404
CL Folding 1M
This is one of the first times I've heard of one actually breaking. Many times I'll hear of someone replacing theirs after 100-120k and it still looking new. because of this I wondered if it ever would actually break, but I guess this is proof that you can't let it go past 100. One time when searching for the car I have now, I looked at one 98 LS400 with 150k miles on it, and when I asked about the timing belt, they had no idea what I was talking about. I wonder how many people have no idea about this and completely ignore it. Considering the rest of the car is so reliable, I figure that a majority of the very few retired LS400's are due to a problem such as this.
Old 01-30-09 | 11:06 AM
MEANDAFAKA's Avatar
MEANDAFAKA
wahahahhaha, i know. but seriously, double check everything before you have your friend put anything back on. jst to be sure the motor is still good.
Old 01-30-09 | 11:22 AM
PureDrifter
BahHumBug
CL Folding 100000
ehh, most of the time i've seen belts let go (all 2 in post 95 UZ engines) it's been due to a pulley or tensioner locking up and destroying the belt.
Old 07-23-09 | 08:06 PM
Bocatrip's Avatar
Bocatrip
What is the recommended mileage or time in years for the replacement of the LS400 timing belts? I assume climate plays a part as well. Thanks all.
Quick Reply: replace timing belt 96 after break
