Change starter or starter' s kits only? needs expert advice!
Hello All... I've been searching the threads and haven't been able to find anything similar to this.. so if this is a well duplicated subject.. I apologize.
sometimes i hit ignition 8 time to get car engine start.
I tried a new battery but didn't fix the problem. I also cleaned the battery terminals etc. Still problem not solved.
So am planning to change the complete starter or starter' s kits only.
My mechanic quoted me a price of $95 for labor work only +
starter kits (contact repair kits & plunger) cost = $31
http://www.nationsautoelectric.com/instructions.html
for those who have faced this problem?
Is the labor work charge is high or its a good price?
400_starter_replacement.pdf
GRAND_LS_4 has changed his ls400 starter, but he did not included detailed pictures so poeple like me can get this done for free.
https://www.clublexus.com/forums/ls4...y-ex-98-a.html
Experts ...what is better? To change the complete starter which costs alot of cash!!
My mechanic suggested to change the starter kits only, hes saying that will solve the problem. am afraid that changing the starter kits only will not solve this problem. Any way what you guys suggest!?Please help!!
The usual problem with Toyota starters is with the contacts within the solenoid. The solenoid plunger has a copper ring that connects two copper tabs to drive the starter motor. One tab gets burnt away gradually until the ring won't make solid enough contact to pass the current. If you replace these tabs and clean up the ring on the plunger, the starter will go another 200,000 miles.
![](http://us.lexusownersclub.com/forums/style_images/1/folder_mime_types/pdf.gif)
the starter for your car is located under the lower intake manifold and $ 95 dollars for labor sounds way to cheap. mitchel online shows 5.1 hours of labor on a 1990.
knowing what i know i would say replace the whole starter. you would not want to replace only the solenoid and have to dig back in soon there after. take caution when chaging not to disrupt the knock sensors or thier harnesses.
Well, he is in another country, so the premium prices we pay over here may not apply to him.
I would replace the whole damned thing, but if you're trying to save bucks, a rebuild kit will be fine. Just make sure your mechanic dry-tests the starter while the whole thing is torn apart, otherwise, he'll be digging in there again.
Like molex said, $95 is low, your mechanic doesn't realize where it is. Quick, get a quote in writing and hold them to it!! I just did mine myself in December (kit only) and it's a royal pain to do.
ADDED: I read though some of your other posts, Your in the UAE so $95 may be a good price but verify. You have a 2000 and it's clicking. If the problem is just that it clicks, you may get away with just the kit as I did.
More detail please. Is it turning over or just clicking? What year?
Last time before 1 month i had solved this by cleaning the battery terminals, so engine was starting from frist click untill few days back.
Sometimes it crank only without engine start, but after pressing the gas pedal and turning the key to start position at same time --->> it crank and engine starts.
My car is LS400 Model 2000.
Yes am from middle east UAE. It sounds like mechanics in USA charge too much for vehicle repairs (thats why most of you guys prefer to DIYs repairs)..If am in USA then how much will they charge me for repair?
i had read in some website that they charge for labor work of starter replacement in LS400 like $560
some websites saying
if you can hear a click when you turn the key, that means the solenoid is working but the starter is not engaging. This problem is probably the starter motor itself.
Sounds like your starter is dead. Check out this thread, I hope it helps
https://www.clublexus.com/forums/ls4...-progress.html
my mechanic just replaced the contact repair kits & plunger and he fit every thing back in. and tried to start the car, but still same thing...again he digged back in...
The mistake which he made is that he didn't test the starter , he just made a guess that these parts are not doing their job and replacing these parts will solve the problem!
Any way i told him lets replace the whole starter which costs here like 324$ OEM part.
Those mechanic which am dealing with they just depend on their experiance (but their charges are low LOOL) , they are not educated...they don't know anything...any way i hope that replacing the whole starter will solve this problem... wish my luck.
Even I know how to do that, and I am not a mechanic by any means.
[QUOTE=molexGS400;4206554]the starter for your car is located under the lower intake manifold and $ 95 dollars for labor sounds way to cheap. mitchel online shows 5.1 hours of labor on a 1990.
QUOTE]
Yes molex is right $95? what your mechanics number because he is gonna give you a hell of a deal. I did it myself last weekend and I know he is not gonna let you slide with $95... its a pain just to get to the starter and then another pain getting it out lol. All my labor quotes were some where between $400-$600 labor (LEXUS was $600).
QUOTE]
SuicidnS13
Performance & Maintenance
11-02-10 08:51 AM
