LS400 ring and pinion compatibility
Old 05-21-15, 09:26 AM
nismo4life
nismo4life's Avatar
Bumping this from the dead. I have a diff I broke something on so I'm pulling it out and I want to take the actual diff out of the housing and measure it to find out what we can swap in. Can anyone tell me exactly what I'm measuring to find out cross comparability?
Old 05-21-15, 12:52 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
what are you trying to accomplish exactly?
Old 05-21-15, 06:12 PM
lexispoold
lexispoold's Avatar
What year LS? If the auto supra/GS/SC is compatible I have a brand new one in box for sale
Old 05-28-15, 10:59 AM
nismo4life
nismo4life's Avatar
To find out what someone else was asking and was never answered. If the stock differential is the same internal dimensions as any other Toyota equipped LSD so I can stop sliding on a welded diff. Car is a '92.
Old 05-28-15, 02:13 PM
PureDrifter
BahHumBug
you should be able to use a mkiv supra LSD, either OEM automatic torsen (USDM) or the aftermarket clutch type of your choice for the same vehicle.
Basically you should be able to use a 200mm ring gear 4th gen supra LSD. You can NOT use the 220mm ring gear internals found in the USDM 6spd turbo. Japan mixed and matched the two diffs so if in doubt, measure the ring gear as the 2 R&Ps are NOT interchangeable at all.
I've got a mkIV torsen in my '99 LS400 right now, it's nice .
Old 05-30-15, 09:59 PM
nismo4life
nismo4life's Avatar
Oh I bet. I dream of driving without accidentally putting the car sideways around turns….well no not really but it would be appreciative to my driving record so that it stays clean hahaha. How should I measure the ring gear. End to end is 200mm across?
Old 06-01-15, 03:40 PM
PureDrifter
BahHumBug
you can but it'll be nigh-impossible without taking it out of the car. I'm pretty confident you'll be fine.
200mm OD is what you want, 10 bolt, ~150mm bolt-center diameter. ~127mm ID.
Old 06-02-15, 10:46 AM
nismo4life
nismo4life's Avatar
Well I'm replacing the entire casing with a junkyard one. Broke something inside on a clutch kick lol.
Old 06-02-15, 04:41 PM
PureDrifter
BahHumBug
make sure to update, would be nice if you could confirm finally that the internals are interchangeable.
KalimaD
GS - 1st Gen (1993-1997)
11-20-13 05:21 PM
ef9racer
11-02-12 02:45 PM
fastegg
12
03-18-10 12:30 PM
TomWahjudi
01-22-03 08:05 PM
Blue
08-31-02 12:17 AM
Quick Reply: LS400 ring and pinion compatibility
