Dash Cluster
Old 02-12-09, 10:19 AM
49er_Gurl
49er_Gurl's Avatar
Default Dash Cluster
I am not sure if anyone else has ever experienced this problem or not...I was driving on Sunday afternoon and my 1990 LS400 was working just fine. We took a 2 hour trip and had no problem on the way there. However, when I was driving home, ALL of the lights on my dash came on and would not go off. I felt the top of the dash and it was warm. The car was running just fine, not ever heating or anything like that. I made it home just fine and let my car sit. When I turned it on again later that afternoon, the lights were normal again. I am not sure what is going on. Has anyone else experienced this problem? If so, what is going on with the cluster. Oh and I forgot to mention, a couple months back, while taking another trip, the speedometer went out completely. My car is a 90 and has only 102000k.
Any information would be greatly appreciated.
Old 02-12-09, 11:04 AM
McSwine
McSwine's Avatar
Read thru this thread and see if it helps.
https://www.clublexus.com/forums/ls4...000-bucks.html
Old 02-12-09, 12:42 PM
49er_Gurl
49er_Gurl's Avatar
Thanks I will check it out!
Old 02-16-09, 08:12 AM
JWCATTO
JWCATTO's Avatar
The other day my car did the same thing. The radiator, oil level, parking brake, Battery, and check engine light came on. Let the car sit overnight and cranked it up, presto, no lights on.................don't get excited yet. They came back on after driving and hour or so and then the car shut off 30 mins later. My alternator is dead. Those lights come on as a warning, do not ignore them. If your case is something different, who knows :-)
Old 02-16-09, 01:09 PM
420man361
420man361's Avatar
Default common problems
almost all gauge clusters in 90-94 ls400's have problems due to faulty components. got mine fixed for about $200. i found a guy on ebay that upgrades them with better components so that it doesn't just mess up on you again, as would happen if you took it to a dealer, which would cost $mucho$ anyway. hope this helps
Old 02-16-09, 05:01 PM
allegoric1
allegoric1's Avatar
Default dash cluster repair
care to share who repairs these dashes, heard it was $195, but who, address and contact info would be appreciated.
Old 02-16-09, 05:25 PM
LiCelsior
Retired
LiCelsior's Avatar
when multiple lights come in...usually means a failing battery or alternator. the cluster problem is usually unlit background, fuel meter not reading correcting and the tacho or speedo not moving until it gets warm. this could be done for <5bucks if u have decent solder skills or know someone with solder skills. u just have to buy some capacitors which are <5 bucks.
Old 02-17-09, 09:37 AM
420man361
420man361's Avatar
the guy's ebay store is "auto & truck electronics", i don't know if they do buss. outside of ebay. but just go there, and type in your year model gauge cluster, and you should find them easy
airahcaz
11-13-15 06:18 PM
kaban1993
SC- 1st Gen (1992-2000)
06-27-15 10:44 PM
JLund
12-18-08 11:18 PM
lexdiamonz
05-18-08 09:23 PM
Sean1692
01-23-07 04:35 PM
Quick Reply: Dash Cluster
