Bouncy Idle '95
Hello fellow Ls400 owners I just finished replacing my starter in my 95 Ls400 but now the idle is bouncy and the engine is not running smooth like before.
What would cause this?
I was thinking vacuum leak but i checked all the vacuum lines and they are fine.
I reused my throttle body gasket....maybe this??
![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
Now its the part of getting it to run right..
So the exhaust leak prior to the 02 sensor would have nothing to do with my bouncy idle??
Yea i thought it was unlikely that each injector would only be set per cylinder.
I went to My local Auto Zone and got a scan and it came up that 7 cylinders are misfiring.
So only cylinder number 8 is working properly.
I think i might just go to my Leuxs dealer and get a diagnostic
^ Checked and there all were they are supposed to be.
The top ignition coil has a plug on the bottom with two wires.
Well that plugs plastic broke so I was left with only two wires not knowing which wire went into what side of the coil.
I think since they mixed up and i started the car it might off messed up something electrical.
What i did was triAL and error. I switched the wires until i saw which one ran better.
But maybe it messed something up on that initial start when the plug on the bottom of the ignition coil and the two wires were mixed up.
Oh yeah another thing is that now my steering wheel will only go up and down. It doesn't go in or out anymore. Checked fuses and nothing?
