Got my new wheels...
#46
i say 15mm, you measured 1/2 inch, which is 12.7mm, so take your pick, the proper kind of spacer you need (hubcentric for toyota/lexus 60.1mm bore) is available in 5mm increments, unless you feel the need to cheap out on some non-hubcentric 1/2 generic spacers, in which case you WILL have massive vibration and will possibly watch the wheel part ways with your car while on a highway.
If you're wheels are originally 19x8.5 +35, after adding a 15mm spacer it will be 19x8.5 +20. for that you will most definitely need a fender roll, possibly a pull, and if you arent lowered it WILL look like a 4x4.
#50
Thanks licelsior. Here is the link for the ones I found on ebay. http://cgi.ebay.com/ebaymotors/5x114...Q5fAccessories
Are theses worthwhile? I will check the vendors here also.
#52
Originally Posted by PureDrifter
ichiba sells bolt-on adapters that range from 15-25mm.
http://www.ichiba-usa.com/lslsls.html
plus you won't need centering rings, these are hubcentric to toylex cars at 60.1mm centerbore.
only catch is that the wheels have to have spaces in them for the oe-studs to protrude
(look like this:![](http://site.ichibausa.com/Dave/open01.jpg)
they can NOT be solid.)
if they are solid then you can't really use any adapters, you'll have to to get something like Ichiba's V1 spacer and some extended studs to press into your hub, more work but you wouldn't really have a choice.
(look like this:
#55
After its all said and done, time and wheels spacers....here they are!
The fronts stick out just a tiny bit but not noticeable. Now its time to lower and wash this car!
![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
