91-92 vs. 93-94 Bottom Panels
Old 03-04-09, 08:51 AM
RandomHero
RandomHero's Avatar
Default 91-92 vs. 93-94 Bottom Panels
Just curious, what (if any) are the differences in the rear pieces on the 91-92 models vs the 92-93 models?
I am aware that the 91-92 don't have painted sideskirts.
For instance, I found some replacement bottom panels from a 91 that I'd like to throw on my 93...will this work?
Thanks guys!
Old 03-04-09, 09:15 AM
python
python's Avatar
did u check into that grille from the link i sent you?
Old 03-04-09, 09:17 AM
RandomHero
RandomHero's Avatar
LOL - SO weird - I was literally just in the middle of responding to your PM!
But to answer your question - yes, I did, but it looks like they discontinued it.
Old 03-04-09, 10:42 AM
LiCelsior
Retired
LiCelsior's Avatar
u want the black ones instead?? i rather have the painted ones...make the car much lower .
Old 03-04-09, 10:44 AM
RandomHero
RandomHero's Avatar
What? No - I don't want the plain black ones?
Where did you get that from?
Old 03-04-09, 11:05 AM
LiCelsior
Retired
LiCelsior's Avatar
u have a 93 and u want to put 91 skirts on it? unless i read it wrong lol.
Old 03-04-09, 11:12 AM
RandomHero
RandomHero's Avatar
BOTTOM PANELS
Not sideskirts, as I stated above I know they are not painted.
Old 03-04-09, 11:18 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
which bottom panel? the ones on the doors? or the engine undercovers?
Old 03-04-09, 11:21 AM
RandomHero
RandomHero's Avatar
The ones on the doors and rear quarter.
Old 03-04-09, 11:30 AM
LiCelsior
Retired
LiCelsior's Avatar
ahh i see...my bads lol. they should fit.
Old 03-04-09, 11:48 AM
Kansas
Kansas's Avatar
The plastic lower body cladding on the 93-94 LS400 is substantially thicker than the lower body cladding on the 90-92 LS400. Apparently the 90-92 cladding is interchangeable with the 93-94 cladding because back when the 93 LS was introduced, some owners of 91-92 LS400s retrofitted their cars with lower body cladding from the 93 LS400 just to make their 90-92 LS cars look newer. It might look strange if there was a mix of 90-92 and 93-94 lower body cladding on a car.
Old 03-04-09, 12:06 PM
farquad
farquad's Avatar
its plastic? didn't know that
Old 03-04-09, 01:15 PM
Kansas
Kansas's Avatar
Yep, it's very high quality molded plastic. If you pry off the lower body cladding, you can see the plastic ribs molded into the back of the cladding to give the cladding rigidity. From my experience, removing the cladding ruins the plastic rivets that hold the cladding to the metal car body ... new rivets must be obtained and used to reinstall the cladding.
bigblack06
01-12-15 09:54 AM
EricOrtiz
01-16-12 05:37 AM
k1ngph1l
09-19-10 11:20 PM
camberSC
Wheels, Tires & Brakes Forum
19
06-09-09 01:55 PM
Quick Reply: 91-92 vs. 93-94 Bottom Panels
