Transmission: Drain or Flush?
Hi All, Can someone tell me if there is a difference between just draining the transmission fluid and doing a transmission 'flush'? If so, what is the difference? Any idea in average costs? I need to get this done soon. Thanks for your feedback.
well our transmissions hold about 12qts of fluid. when u drain, only about 2.5qts drain out... I don't feel like doing the math but that's only about 20%. You would have to drain and refill about 6 times for all new fluid to get in there. BUT everytime you drain and refill with new fluid, you're mixing it with the old fluid that was already in there. I recommend a complete flush so you know all new fluid is getting in there. Its simple, there's a tutorial at lexls.com. but also, for added measure change out the trans filter, put the pan back, add fluid, then do a flush.... did it to my lux, and it shifts so much smoother......
thank you both.
well, good thing I read up. it's exhausting, but i find if i know how to do something before i have someone else do the actual work, that it always pays off.
there are different ways of doing a flush, and the one using a machine that pumps fluid through using pressure would be the wrong move, especially for an older engine. all is explained at these links. there's a better way...or, i can just skip it and drain instead.
http://www.lexls.com/tutorials/trans...anschange.html
http://www.lexls.com/tutorials/trans...ransflush.html
i have no idea if it's true or not, but i have been told not to do a flush. Supposedly "if" there are particles or gunk in the transmission, the flush could dislodge them and leave them in the tranny. Again, i don't really believe this considering you have a filter in the tranny and the point of the flush is to FLUSH all the fluid out. Anyways, these mechanic's logic were that if particles were in there that they were sitting in places "out of the way". If you flush you are just putting them back into the tranny.
i take that with a grain of salt, but i have heard that.
thanks. about 90K miles on it and fluid was changed out (not flushed) about a year ago. i do mostly about town driving, so few miles (less than 5K) on it since then. the fluid is a cherry red. i was told it was dirty. the red isn't real clear...more of a deeper red? i think it should look clearer than it does. maybe just drain all of it out by that non-machine method described in one of the links, replace gasket and screen/filter, clean pan and magnets. that should do it. thanks all...
You may not even need to replace the 'filter'. It's just a metal screen and most of the time when people take it out, it's free of debris anyways. I'd just do a drain and refill for now and see how that goes. Cherry red isn't as bad as other cars I've done. Many cars had brown fluid.
I'd do several drain and fills with T-IV. Sure, you could use a "universal" ATF such as Valvoline MaxLife, but from my experience with it on a Honda don't bother.
WTF, the god damn filter with the gasket is like 20 dollars. why are everybody want to just clean the screen?? autozone, napa, and any other store sell the filter kit which include the csreen, and gasket for ONLY 20 dollars. go do it right, and stop being cheap.
