Transmission Throttle Cable Adjustment
Hey can u help me Please? Im Trying to fix a slip in my Transmission but i cant see .
wanted to bump this to share my discovery. I had transmission jerk from P to D as well as R. Also between all gears.
I first thought it was trans mount or oil. Changed those but no improvement.
Then I thought it could be the drive shaft bushing etc. But no...
It was this cable that was little too loose. Basically the transmission was thinking car was at lower RPM than it really was, resulting in the jerk. Took 5 minutes. I can barely feel it shifting now.
Very easy to do, as cation said above, there is a stopper on the cable and it should almost touch the cable outer. (<1mm)
This is a must do DIY i think...[/QUOTE]
Transmission slipping please Help
Hello everyone this is my first try here ,and I would like to thank everybody in advance for all your help. I have a 1993 ls400 it has transmission slipping problems, about 3 days ago it starte. sLipping on me when I got off the expresswayI would go to accelerate and it would barely move.I thought the car up and when I shift from park to drive it would go for a while with a winding noise then after about a mile it will stop moving and I'll be sitting there for a minute.then I'll start the car and let me drive again for a while about two miles and the same thing happeNs.can anybody help me with suggestions can you show me a diagram where the throttle cable is or how to adjust itI would really appreciate it thank you so much have a good day
Throttle Cable / Cruise Cable / 3rd cable no clue
Recently tore apart entire engine replacing valve cover gaskets. stuck in water on throttle adjustments.
1st cable top front one on my 1997 sc300 need help
2nd cable keeps falling off thinks its cruise
3rd cable not sure what this one is but has some slack
all 3 need adjusting please help with tips and tricks
Thank you
Guiderm31
Mike
Thank you
Guiderm31
Mike
