tweaking stock suspension '98
I'm likely facing some front end work soon on my stock/original '98LS w/130k mi. on it. I'm still getting to know the car but like the stock look/ride for now. Plus I don't have the budget to do wheels/tires or big suspension mods now even if I wanted to. I'd like to reduce the body roll/ improve cornering if I could do so without compromising the ride too much. Anybody have any recommendations for alternatives to stock parts like shocks, bushings etc. that I should consider in order to tighten up the ride while still being compatible with my otherwise stock suspension? I like that big car ride, but when I'm in the mood to float I go with my '59 Caddy, and when I want to break the sound barrier on exit ramps I've got the Saab Aero; I'm looking for a middle ground.
Dave
'98 LS
'59 Cadillac Fleetwood 60S
'02 Saab Aero Wagon
Dave
'98 LS
'02 Saab Aero Wagon
1. Front strut tower brace( if you can find them)
2. Polyurethane bushings
Have to remember that the LS is a big car and really was not meant to be thrown into corners, is def. not a speed machine of any means, and will sway due to the weight of the car. There are ways to improve upon some of these points but that will involve suspension work, and since you stated that you liked and wanted to keep the stock ride, for now, these things I have listed will help out a little, but until you change the stock setup to something aftermarket just sit back and cruise on down the highway.
confirmed that the 98-00 LS400 will accept a 93-01 Toyota Supra Turbo bar without any modifications to either bar or engine cover, and clears everything just fine.
STB, poly sway bar bushings, and if you wanna spend up, Bilstein shocks+H&R springs. will handle MUCH MUCH better.
Thanks, all. Learned today that my problem is worn radius rods, which caused a tire to go out of round. But I'm going to look into getting a pair of Bilsteins. I've had good luck with those in the past on an old air suspension MBZ.
I don't have anything to contribute other than:
1959 Cadillac
1959 Cadillac
![Big Thumb Up](https://www.clublexus.com/forums/images/smilies/biggthumpup.gif)
I'm running KYB GR-2s and Daizen front bushings. It does make some of a difference. I also have 215/55R16 Michelin Pilot Exalto A/S - they are "low" profile compared to the stock 205/65R15, but I have less sidewall flex, meaning less "wallow".
Now I'm back in action w/ new front struts and radius rods, and the out of round tire moved to the rear for now, and the car drives much better, but I think PD is right; I should replace the rear shocks as well (and probably the tire too).
Paulo-glad you appreciate the beast '59. I've always found it interesting to compare the LS to the Caddy- when new they were targeted at the same demographic-40 years apart. About the only thing they have in common is that they both have 4 cigarette lighters/outlets.
justdance
07-30-21 06:23 PM
