brake wear light stays on after replacing brake pads:sad:
brake wear light? u mean u have a light on the dash that reads..."brake" here is a bit of advice for anyone who may not know this .....when u are compressing ur calipers to put ur new pads in, make sure u dont push the fluid back up into the master cylinder through the abs unit.....loosen the bleeder valve and let the fluid go out that way.
by not pushing fluid back through the abs unit? that is abs brake 101...some things u dont learn by reading a book, being a mechanic and being around mechanics and having hands on experience will give u more information than any book, but here is one article i found....feel free to read
http://autorepair.about.com/library/a/1i/bl836i.htm
while it does make sense I am pretty sure that provided there isnt any 15 year old brake fluid in there you should be alright without opening the bleeder valves. Mind you, i'm pretty **** about keeping the brake systems on all the cars i work on/own in slightly OCD shape (my car's due for a full ATE Super Blue flush next oil change, been 20k mi almost) so YMMV. Personally, i've never heard of anything bad coming of doing it the old way on any older cars with even decently maintained brakes.
