airbagt light flashing
Old 03-20-09, 08:20 PM
g3t0ut
g3t0ut's Avatar
Default airbagt light flashing
hey so i just wired a amp into my car and now the airbag light is flashing when the car is on.. i have searched and did find the fix but i just want to make sure that the flashing is normal and it doesnt mean something else is wrong. other then a code 22
thanks
Old 03-20-09, 08:58 PM
LiCelsior
Retired
LiCelsior's Avatar
check www.lexls.com and look at the code diagnostics...tells u how to remove that code.
Old 03-20-09, 10:13 PM
trukn1
NELOC Mod
trukn1's Avatar
Airbag light flashing is not normal at all. means there is something wrong with the airbag system. What did you wire your amp to? Code 22, IIRC, is a coolant temp sensor. Go back and double check your connections, clear the code and see if it pops up again.
Old 03-20-09, 10:25 PM
LiCelsior
Retired
LiCelsior's Avatar
22 - Airbag warning light system
Old 03-20-09, 10:44 PM
g3t0ut
g3t0ut's Avatar
well i think what might have happened was the key may have been in the on position when the power wire was plugged in. wouldnt that do it?
Old 03-20-09, 11:01 PM
trukn1
NELOC Mod
trukn1's Avatar
That vey well may have done so. You are gonna have to clear the code to make sure it doesnt come back again.
I really do need a new manual. Have an Haynes Computer Code manual, had it about 7 years, it has code 22 as a coolant temp sensor. LOL!! Live and learn.
Old 03-20-09, 11:42 PM
g3t0ut
g3t0ut's Avatar
alright! well ill do it tomorrow.. ill let ya know if i run into any trouble
oraneivey
01-12-17 12:02 PM
SurfJunkie
12
01-11-17 04:16 PM
MoogieBoogie
SC- 1st Gen (1992-2000)
05-03-05 10:36 AM
Quick Reply: airbagt light flashing
