Position of Engine Coolant Temperature Sensor
I searched but could not find a pic.
Is the ECT sensor of a 96 LS400 at the same position of the engine as that in a 93 LS?
I need a confirmation before I tear the engine apart.
Thanks.
Thanks.
![Thumbs up](https://www.clublexus.com/forums/images/icons/icon14.gif)
On the '93 it's under the ignition coil. Be sure you are looking at the plug with the 2 wire connector, not the one wire. Also, there is a copper washer you must re-use - don't lose it. Don't use teflon tape. Use your sparkplug socket to remove it. Torque is not critical - firm tight, not gorilla tight.
Studiogeek
Performance & Maintenance
03-11-13 06:02 PM
