Great repair service climate control and ecu
Old 04-22-09, 03:33 PM
Och
Och's Avatar
Originally Posted by 91ls400own
How about fast idle ( around 2000RPM)
Nah, thats probably the TPS or something else.
Old 04-28-09, 01:09 PM
bdshomes
bdshomes's Avatar
Thanks for the great info.
Does anyone know who repairs faulty LCD displays on the radio? Mine does not display the channels properly!
Thanks,
bryan
Old 06-18-09, 09:11 PM
dada
dada's Avatar
Default please help to figure this out
my 94 LS400 has 115K and check engine light come up when gas pedal is stepped down little harder than mild gentle.
It will stay on for like 5 seconds then go away, speed won't go up while the light is on.
But if i drive it really slow and don't do quick acceleration, everything is normal.
Does anyone see this problem before? is ECU gone bad?
Old 06-19-09, 06:36 AM
BLKonBLK98
BLKonBLK98's Avatar
sending my cc to them for repair today.
Old 06-19-09, 09:53 AM
avalon42
avalon42's Avatar
Pull the Check Engine Light Code the minute you get it again, if you can.
http://www.lexls.com/tutorials/intro/codereading.html
Sounds like your AFM may be screwing up.
Old 05-08-10, 06:05 PM
jwroblesk
jwroblesk's Avatar
I just called ATE for a quote on a 93 ls400 climate control lcd repair and they said $189. I told them about this list and they still said $189. Go figure!
Old 05-08-10, 10:11 PM
willhickey
willhickey's Avatar
haha that sucks i want mine done !!!! but for 99 tho haha
Old 05-09-10, 07:09 AM
BLKonBLK98
BLKonBLK98's Avatar
http://cgi.ebay.com/ebaymotors/LEXUS...Q5fAccessories
Old 05-10-10, 02:14 AM
jwroblesk
jwroblesk's Avatar
Thanks, I did end up on EBAY and found one of the less expensive services. We'll see how it works out.
Old 05-11-10, 05:12 AM
williamb82
williamb82's Avatar
idk about this company. i sent them the ecu from my ls400 a lil over a month ago to be repaired and noted exactly what was going on and the error 41 etc.. and that the tps checked out good etc... got it back. same issue. so then i tried a brand new tps, same issue, checked the wiring from the tps to the ecu, its good, checked voltages with tps plug unplugged and the vta wire had 1.7v on it. obviously something wrong with the ecu. so i had to send it back under warranty, spending my own money on shipping to them again because they didnt fix it properly the first time. im still waiting for it to come back to me so i can try it. i hope they have fixed it correctly this time or ill be demanding a refund and suggesting that no one else deal with them.+
btw, you can buy the lcd to fix the climate control yourself on ebay for ~$60 shipped.
Old 05-12-10, 12:47 PM
williamb82
williamb82's Avatar
well, just got a call from ate, they say they found the burnt out component in my ecu and have replaced it and are shipping it out today. they received it on 5/4/10 according to the tracking info from fedex. i hope its actually fixed this time. its been over a month without the car because of this.
Old 05-14-10, 03:16 PM
williamb82
williamb82's Avatar
well, got my ecu back today. not only am i STILL having the same problem and getting code 41. im also getting code 47 for the sub tps, which my car doesnt even have as it doesnt have traction control. i do not recomend this company at all. they were already closed when i call them. i will be calling monday to request a full refund. this is the 2nd time i have gotten the ecu back that it hasnt been repaired correctly. its been over a month without the car because of these people.
Old 06-04-10, 07:00 PM
j stuff
j stuff's Avatar
suck to hear william im thinkin bout sending mine in
anyone else have anything to say?
Old 06-07-10, 07:04 AM
williamb82
williamb82's Avatar
id use a different company. seriously.
Old 06-09-10, 11:04 PM
racerblx
racerblx's Avatar
i did my climate control in my 91 couple month ago from ebay, it was 75 dollars and they even called me to tell me that when they are shipping back my stuff.
Quick Reply: Great repair service climate control and ecu
