Great repair service climate control and ecu
Old 04-10-09, 09:40 AM
91ls400own
91ls400own's Avatar
Default Great repair service climate control and ecu
HELLO FRIENDS
I recently purchased a 91 400 and last week a 94 400. the 91 had of course, a bad LCD on Climate Control unit and I sent it in to Auto & Truck Electronics for R&R of LCD. They replaced the LCD and all burned out bulbs for $ 99.00 and return shipping included! Now I have the 94 and found out they also repair ECU's. Well last week they were charging over 200.00 and I found a place that did ECUs for 100. Well I spoke to them and they now will repair Lexus ECU's for $ 99.00 same as Climate Control Units>
I really liked the treatment I have received so far so .... here is their web site: http://autoecu.com/ on top there is a blue line that has links choose the one that states: "Active Listings" this will be a link to purchase their service thru Ebay. That is a safe way to purchase their service as they accept Paypal and that gives you some assurance and comfort in the transaction.
I HIGHLY recommend them
No I am not related but want to pass on a great way to repair our beloved pets.
Old 04-10-09, 02:44 PM
91ls400own
91ls400own's Avatar
Ps let them know you found out about them on the lexus club post from marcel! I told them i would recommend them to the members! Maybe we can pick them up as a sponsor a little later!
Old 04-13-09, 09:56 AM
tyncobb
tyncobb's Avatar
Question 1994 LS400 ECU repair
I also have a 94 LS400 with 300K+ miles. Just recently have noticed a hesitation at start-up and also when coming to a stop and/or idle. Think I would like to have my ECU repaired by your recommended service shop.
However, I don't know where the ECU is located and how to get it out or install it once repaired? Can you help me with the location and how hard it is to get out or to install?
Also, assume that when it is out of the car, I will not be able to drive it? How long did it take for them to repair the part once you shipped it to them?
Thanks for your help.
Old 04-13-09, 12:21 PM
JAndersson
JAndersson's Avatar
Default Engine ECU location
The engine ECU is located behind the panel under the glove box. To take it out you have to
1) Remove the panel at the passengers feet. It's fasted with clips so it's not hard to take out.
2) Remove the glove box. You need to do this to aces all the screws that holds the panel under the glove box.
3) Remove the panel under the glove box. If I don't remember wrong the the engine ECU is the one at the far right.
And you can't drive the car without the ECU. I have no idea how long it can take to repair. I took mine out to replace it with a Mine's ECU.
Hope this helps.
Old 04-13-09, 12:36 PM
Yotarip
Yotarip's Avatar
ecu removal with a little more details.
To remove the ecu (disconnect battery) open the glove box and remove the inner liner by poping out the small round clips in the floor and roof of the glovebox. You will have to remove the little arm that is attached to the right corner of the glovebox door. Just pop off the little cover where the arm attaches to the glove box door and the arm will slide off.
Pull out the liner and you will see a bolt on both far sides of the gbox hinge that were covered by the liner. Remove them.
Now pop off the very lower panel right above the footwell. Now Look under the dash and remove the 10mm bolts that attach the middle panel section. There are about 4 of them.
There is one more bolt behind the uppermost carpet section that goes along the console. peel the carpet back right there and remove that bolt. The panel will come out and the ecu is bolted to that.
Old 04-18-09, 09:48 AM
91ls400own
91ls400own's Avatar
Default Repair time
The folks had a 24 hour turn aound time on my ECU and Climate Control!
Just got back the ECU yesterday and what a difference it made. $ 99.00 lifetime warranty! Normally 24 to 48 is standard for them
Marcel
Old 04-19-09, 02:44 PM
RAINBOW
RAINBOW's Avatar
Default Depends how far you are from Tenn.
I sent my ECU to ATE on a Monday(reg ground )they probably got it late Tues. early Wed.They did their fix in one day and sent it back out Thurs. and I'll get it Mon.(a week turn around) If you can't do without your car, pay for 1 or 2 day air and get-r-done.
Old 04-19-09, 02:54 PM
avalon42
avalon42's Avatar
Marcel
Can you elaborate on the difference?
Old 04-20-09, 03:47 PM
Och
Och's Avatar
This is from the PM
Originally Posted by Och
Hey, I saw your post about your ECU being repaired and it making a big difference - can you tell me what kind of problems you had before the repair and what improved after the repair?
The car was VERY slugish 0 to 30 in minute not seconds, hard to start missing etc
now ok
Old 04-20-09, 10:11 PM
91ls400own
91ls400own's Avatar
from the PM? PM? explain please
Old 04-21-09, 03:26 AM
Och
Och's Avatar
PM = private message, just posted then information you sent me in the private message so everyone would be informed on what issues this service fixed for you.
Old 04-21-09, 09:24 AM
davegrif
davegrif's Avatar
I bought their Climate control service from ebay and am also very happy with the service and the end result. The price was also $99.00.
Old 04-21-09, 09:51 AM
McSwine
McSwine's Avatar
I wonder if the ECU fix would remedy the low idle problem I have?
Old 04-21-09, 10:10 AM
Och
Och's Avatar
Mcswine, low idle usually has nothing to do with ECU. Most of the time its two things.
1) Dirty throttle body
2) Leaking air valve on the bottom of the power steering pump
or both.
Old 04-22-09, 02:47 PM
91ls400own
91ls400own's Avatar
or both.
How about fast idle ( around 2000RPM)
Quick Reply: Great repair service climate control and ecu
