Dropping your car causing clunking?
I recently lowered my car 90 LS400, on megan racing coil overs to a pretty damn low stance, and now, I have problems with shifting gears in my car. weird clunking noises coming from the tranny. any help?
So there couldn't any chance it's the driveshaft hitting the tranny? as the car is PRETTY damn low now. also the shifts from 1st to 2nd then to drive are slippery. the car also sometimes hesitates when taking off from a stop.
"learn about how a tranny works. then come back and please explain to me how the driveshaft is going to hit the transmission" haha what a nice reply right on for the hint of helpfulness in your replies. After driving the car around for a bit today, I noticed that at freeway speeds, when i step on the gas the tranny gives a really hard, how to say it..kick. then when i step off the throttle, it does the same "kick" again. any help that doesn't raise hostility?
it's not your coilovers, just a coincidence. check trans mounts. the driveshaft won't change height no matter how high or low you set the car... the suspension is independent from teh driveshaft. only on an old solid axle car would that become an issue.
Self-righteousness:
confident of one's own righteousness, esp. when smugly moralistic and intolerant of the opinions and behavior of others.
Understanding:
a state of cooperative or mutually tolerant relations between people:
Jitters
Understanding:
Jitters
Self-righteousness:
Understanding:
Jitters
Anyways..... Would continued driving of the car in this state really mess up the tranny?
Understanding:
Jitters
Just a thought but have you attempted to raise the car back up to it's normal ride height to see if the symptoms persist? I would probably start there.
I don't see how lowering the car would cause the transmission to slip. I do however, agree with PD, that if you are experiencing a knock when shifting in and out of gear, that it could be related to the trans mount being broken...just a thought.
Personally, I would not want to drive the car based on the symptoms you've described...
Good luck and I hope you find a solution to your problem...
Jitters
Jitters
well thanks for the help and one last thing...does anybody know any places for finding the tranny mount? or any websites? any suggestions at all?
