Extended wheel studs
Hello all,
New here; have a problem. Got a set of Radd Wheels RD10 20's got them from a guy who had them on his 1991 LS400. Trying to put them on my 1997 LS400 the backs fit just fine, the fronts won't clear the calipers who has 2" extended wheel studs for the LS400? seen them for the IS but can't see those working. Help Please!
Need to provide us information on the wheels. You state that they are 20's but what else? 20X?,,offsets?? tire size?? etc. The 91 had smaller brake calipers, which may explain why they were able to fit/clear. Every model LS from 93/94 and up got an improvement in their brakes(bigger calipers than the 91) and this may explain. More info is needed to assist with your problem.
245 30 20 is the tire size I don't know the offset I just need to know where I can find extened wheel studs for the LS model like they have for the IS model. I have the spacer but this doesn't give me enough room with the exsiting wheel studs.
Studiogeek
SC- 1st Gen (1992-2000)
05-22-14 08:58 AM
