help! got some faults in my suspension
i dropped my car on eibach sports springs and tokico shocks.. for some reason.. everytime i go over dips or uneven roads.. my FRONT suspension makes this noise as if the suspension is loose.. cling cling sound i dont really know what it can be? any suggestion from the experience people? maybe i forgot to do something when changing the springs and the shocks?
please help!
please help!
Same springs and shocks.... SAME CREEKING NOISE. Very annoying and doesn't sound too good for a Lex.
btw... "easy fix" , can you please be more specific?
I read another post saying that the whole sway bar assembly needs to be replaced. I go to a local autoshop that specializes in Toyota and Lexus [Certified and trained from the dealer] ... they wouldn't even touch it without replacing everything. Then again, could be a "dealer recommended" thing.
ThanX in advance
TD
ThanX in advance
TD
Search Function Inc.
I suggest you go to a toyota mechanic and he will tell you whats up for real. Dealer mechanics like to replace the whole system since it costs more for you and easier for them. One of the bushings needs to be replaced, not the whole assembly.
what i found out..
i went to the carcraft center here.. and i am able to find out what's making all the creeking noise.. its from the lower control arm ball joints.. my makes the noise cuz the lower control arm ball joints are totally out.. you guys might want to check that out..
charlton
charlton
IS3RACERMAN
Suspension and Brakes
06-30-01 12:07 AM
