00' tilt wheel only extending 50% of time on start-up?
On my 2000 LS 400, when you put the key into the ignition the wheel is supposed to tilt down and extend out. Well, recently, when i put the key in the ignition, the wheel will tilt down, but not extend. THis is happening about 40% of the time.
So i took the cover off the column. I see the extending gear which is a worm gear, and the wheel column attachment to that worm gear. The bushing in the attachment (don't know the real name) appears to be torn and worn out.
I have a pretty good hunch this is the cause.
Anyone else had this problem getting good extension? Wait, what!?![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
is this bushing serviceable?
Depending on the VIN number of your 2000 LS400, one of the TSIB's I posted in the following thread might be useful - or at least show how the mechanism works: https://www.clublexus.com/forums/ls4...ion-00-ls.html
Thanks Kansas. It appears that my worm drive motor is different from the one that is pictured in the thread you posted a link to. When i downloaded the TSIB PDF also provided in that link, it seems that from what i can make of the exploded parts diagram, i must have the newer motor.
I will look at this a little deeper over the weekend.
Right now mine starts to telescope out, but it squeaks and then just stops.
EDIT:
After looking at the attached PDF. the last few pages shows exactly the type of motor and worm drive i have. hmmmmmmm.... so where does that leave me?
If you look at the exploded view on page 9 of 10 in the pdf, the "thrust ball bearings, steering main shaft bushing stopper" are the parts that seem to be fawked! That i can see visually anyways. I may take this document to the lexus dealership this weekend just to see what their take is on it.
EDIT:
Shadeed
18
06-02-23 06:24 PM
oldyngoody
09-18-12 11:39 AM
SpencerT
05-31-12 02:16 PM
