Headlight adjustment
I just did mine and it took me a sec to figure it out. The manual just shows the level but not the adjustment points. The horizontal adjust is easy and on the upper outer corner of the headlight. The vertical was the hard one to see. Its located center bottom of the headlight and is a long silver 8mm bolt that sticks out of the black housing of the headlight. I had to remove the air box to access the RH center adjust.
