Replace Fuel Injectors how often?
#32
There isn't one thing that I did that made the car magically better, everything I did incrementally made things better, but not good enough. All leading me to believe it's the injectors because things like I did would not fix an issue such that is spark related.
#33
If it sat for 2 years, the gas that was in it was varnish. Did you drain the fuel before you ran it? If not I bet that's your ultimate problem. I had a car that sat for a year and the gas was old. That is exactly how it acted. Misfiring, no power, running rough. I changed the fuel filter, and ran fuel injctor cleaner thru it every tankful for about 6 tanks and it slowly got better, then went away altogether. If you take the gas cap off and it smells funky then you're gas has turned to varnish.
#34
its not coincidence that the people at napa were the most knowledgable, and i was suggesting u ask them for a good shop, not to have them diagnose ur car, and the only thing u have made clear is ur ability to keep asking questions but come across as u know what u r doing....u have argued every point people have made and yet here you are with a car that runs like crap....so u just keep being arguementative and see where it gets you...owning a car that runs like crap
#35
Python: I know what you mean but just relax and give him the benefit of the doubt, as maybe he is just trying to learn as much as possible. If you have said all you can constructively, then you don't need to add anything more as your car runs fine. I understand your trying to help with it, but just don't answer his questions if you don't have anything more to add
However Goku2, as Python stated, many people have answered your questions. The problem isn't going to fix itself, but instead you will need to put some time and effort, and definitely money, if that is what you don't want to hear, then I'd suggest not owning a Lexus. Sorry but as a Toy/Lex tech, it is impossible to diagnose a car over the net, let alone see if your injectors are all pulsing, I have given you my 2 cents as a technician. Good luck with your car.
#36
Yeah I know the problem isn't going to fix itself, I'm just trying to run through all the possible scenarios and trying to be critical about each point. I talked to one of the lexus techs and asked them how they would determine which cylinder was misfiring, they said by matching up with the exhaust note, and attaching what I think is basically an oscilloscope to each of the injectors, they could tell which one was misfiring or something. Do you guys know of anything about such procedures? He said he would attach the probes to the wiring harness but when I looked at the wiring harness, I saw that most of the electrical connections are inaccessible unless I ripout the intake manifold. He mentioned maybe probing the connectors near the ECU. Either way, I was hoping you guys would be aware of some diagnostic procedures. Also is anyone able to confirm 100% that you need to take out the intake manifold in order to get to the injectors?
#37
look at ur fuel rails, the manifold does not need to come off. u can remove all the injectors but leave them hooked into the fuel rails and see if they have an even spray pattern...if u r so intent on having ur injectors checked u might as well send em off to witchhunter...http://www.witchhunter.com/
#38
jared5
47
12-14-22 02:08 AM
DroppedGS
04-08-04 12:00 PM
