Need to change catalytic converter for LS400,1996
Old 05-23-09, 08:06 AM
simonyu
simonyu's Avatar
Default Need to change catalytic converter for LS400,1996
I have P420, P430 codes on my LS400, 1996, check engine light is on . Do I have to change both catalytic converters which would cost more than $1000? Could I just change O2 sensors or the converter gaskets and how do I verfiy that before I purchase these parts
Old 05-23-09, 08:35 AM
LiCelsior
Retired
LiCelsior's Avatar
check to see if theres any leak at the converter gaskets.
Old 05-23-09, 12:29 PM
boris
boris's Avatar
Simon, I have a 95, had to replace cat about 2 years ago. It was done by a very trusted mechanic and he used A&B cat. I have not had any issues. But true first make sure that the other parts are not causing the code to go off. I had replaced first the oxygen sensor to no avail. I mostly due my own work but was in a hurry so had him due the cat. Hopefully this helps.
Old 05-23-09, 12:41 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
replace the gaskets first, clear the codes, then drive it. if that doesnt work, replace both the post cat O2 sensors. THEN LASTLY replace the cats if those 2 fixes don't help.
Old 05-26-09, 08:56 AM
jcrome04
jcrome04's Avatar
Got any part numbers off hand for the Cat gaskets?
I have these same codes.
I you don't have them I guess I can put in a little more effort and call the Lexus dealer haha
Rayyan
Performance & Maintenance
05-10-18 06:15 PM
dimelobigm
ES - 5th Gen (2007-2012)
11-22-15 02:05 PM
flyboyplo
05-09-14 08:30 AM
mr3gs300
Maintenance
12
02-06-12 11:25 AM
babyboost
IS - 1st Gen (2001-2005)
12-12-10 11:51 AM
Quick Reply: Need to change catalytic converter for LS400,1996
