UCF20 Warm Low Idle/Stall - easy workaround
Old 06-16-09, 12:48 AM
gmacrae
gmacrae's Avatar
Default UCF20 Warm Low Idle/Stall - easy workaround
I got sick of my 95 LS400 stalling when pulling up after a long highway cruise. I had cleaned the throttle body, cleaned the IAC valve, replaced air filter etc etc, and the problem persisted. It definitely seems like the ecu closes the IAC valve when cruising at highway speed, but forgets to open it back up when you pull up to stop. I refused to just get into the habit of turning the a/c on when pulling up. I dont like my chances of finding a replacement ecu here that actually sorts the problem.
My fix required about 30cm/12" of vacuum hose (2-3mm i/d), and a single T piece (4mm i/d).
The aim was to feed the engine a small amount of extra (AFM metered) air, so that when the IAC stays shut, the engine is still able to feed itself enough to keep idling.
First, cut the vac hose that runs down from the intake to the power steering, insert the T piece inline, then run the vacuum hose from the T to the little unused nipple on the intake toyota conveniently left for us.
This basically increases the engine base idle roughly 300rpm thanks to the perfect size of the unused nipple. The ECU just adjusts the IAC to keep the idle speed where it should be normally.
This also stops the 'jerk' when stepping off and back on the gas when cruising around 80km/h.
Hopefully that does the trick for the rest of you. Questions/comments welcome.
*** UPDATE - this fix is still working perfect roughly 6 months later ***
Gene
Attached Thumbnails UCF20 Warm Low Idle/Stall - easy workaround-dsc02443.jpg
Old 06-23-09, 09:31 PM
DA51
DA51's Avatar
Default Any more stalling?
I was wondering if this tiny bit of air has made a difference?
On the SC page a Toyota Mechanic said that the ISC Valve should removed and cleaned as preventive maintenance.
Viewing the tiny vacuum that you attached compared to the vacuum attached to the ISC, would not the engine need more air at idle?
Old 06-24-09, 02:43 AM
gmacrae
gmacrae's Avatar
Yea, i've been running it like this for months now, going great.
I tried cleaning out the ISC valve, it made no difference, it was already pretty clean.
I dont get your last point? You realise the car still has the stock ISC valve setup right? It just has the vacuum line i installed as well to allow a small amount of air into the engine with the ISC closed.
Old 06-24-09, 04:23 AM
j three
j three's Avatar
I thought there was a service campaign that Lexus put out for the early ucf 20's that altered something in the computer to fix this. If you are not the original owner you should check out the service records to see if this has been done.
Old 06-24-09, 07:37 AM
McSwine
McSwine's Avatar
I wonder if this would work for a 2000 LS?
Old 06-24-09, 11:19 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
no, it wont.
besides, this problem never appeared on the post '98 VVTi engine'd cars.
Old 06-24-09, 12:31 PM
McSwine
McSwine's Avatar
Originally Posted by PureDrifter
no, it wont.
Thanks for your answer, but I can tell you with 100% certainty that this exact problem occurs on my 2000. Like the other dude stated, I have to turn on my a/c after a long freeway run or the car will stall (most of the time; seems to do worse in hot weather).
BNastee (12-21-23)
Old 06-24-09, 12:45 PM
PureDrifter
BahHumBug
this symptoms may be the same but the actual CAUSE may be very different. the 95-97 had an ECU recall/TSB for this exact problem.
Old 06-24-09, 07:10 PM
gmacrae
gmacrae's Avatar
I wondered if lexus did a recall... I might give the dealership a call to see what they say
Old 09-13-09, 08:15 PM
gmacrae
gmacrae's Avatar
Just an update, still going perfect, no stalling problems since i did this.
Old 09-13-09, 08:25 PM
Och
Och's Avatar
Interestingly enough, on UFC10 that nipple is used - it pulls air through the fuel pressure regulator when VSV is open.
Old 01-23-11, 08:48 AM
Mega
Mega's Avatar
Thanks for this writeup. Doing mine today before a 50 mile drive on the highway.
Old 01-23-11, 11:31 AM
Mega
Mega's Avatar
Completed this this afternoon, still have the 50mph shudder, and still have the stall after a long highway drive.
Maybe this mod, and a combination of cleaning the throttle body, and cleaning the iacv help?
Old 01-23-11, 12:59 PM
SRV1
SRV1's Avatar
Gene
Two things to check are the throttle position sensor and the dashpot.
James
Old 01-23-11, 10:21 PM
gmacrae
gmacrae's Avatar
Yea if you haven't cleaned the IAC and throttle body you should, adding that little hose only allows a tiny amount of extra air into the engine, might not be enough to make a difference if both are still clogged with crap
Quick Reply: UCF20 Warm Low Idle/Stall - easy workaround
