What happens if the Camshaft Position Sensor goes bad?
The Camshaft Position Sensors are now changed with working used sensors bought from Lextreme (thank you David!) for a really good price. Got 4 used ones (so I have 2 as spare parts) for less then 1 new sensor cost in Sweden. My problems seems to be gone now. But before I got the sensors changed I changed out my MAF with a used one from ebay because when I did the test as seen below I some times couldn't get a reading at all.
![Name: AFM_test_LS400.gif
Size: 7.6 KB](https://www.clublexus.com/forums/attachments/ls-1st-and-2nd-gen-1990-2000/438258d1501403221-what-happens-if-the-camshaft-position-sensor-goes-bad-afm_test_ls400.gif)
And after I changed out the AFM my problems with "jerks"/misfires never occurred again. So can't really tell if it was the AFM who caused them or if it was a combination between bad cam position sensors and a bad AFM. But my check engine light is not on now after the sensors was changed. Overall the cars seems to run a little bit better now.
ldj250 (10-26-21)
If the crankshaft position sensor is bad the car would not start.
ldj250 (10-26-21)
I have a 1992 lexus LS and the wire horness on the drivers side has power but don't no power like the fuel injecter plugs are getting power but dis and crank shaft sensor is not getting any power but power coils are and when try ot start it up...the RPM stick moves but don't start because the crankishaft is not getting any power
I have a 92 sc400 I have the same type of issue runs like crap when I can get it to start my problem is randomly my ecu loses power and there will be no check engine light, when I can get a check engine light I can read codes fine though code 13 and code 31 code 31 I caused though, does anyone know of any crazy fail safes the computer has that will shut it down before you start it?
Bwolf
05-06-14 07:19 PM
RomanTPA
07-14-10 08:07 AM
