gen 2 brake upgrade
Old 06-25-09 | 11:46 AM
PureDrifter's Avatar
PureDrifter
BahHumBug
CL Folding 100000
Originally Posted by BLKonBLK98
has anyone fitted the rear that you know of? i saw in the write up it was a consideration but was not confirmed to work.
*edit - did a couple more informed searches and found plenty of info. still haven't found confirmation on the rear though.
that's because there's not THAT much point in doing the rear 2LS swap. the 2LS has similar 1piston brakes in the rear, the Supra TT has 2 piston rears. and iirc no, it won't fit. (mounting brackets are different)
Old 06-25-09 | 01:39 PM
python's Avatar
python
just fitted em on after the backing plate was cut to fit, i have the clearance needed but it just barely clears my rims...i mean barely
Old 06-25-09 | 05:25 PM
BLKonBLK98's Avatar
BLKonBLK98
true enough. after looking at the rear caliper/pad/rotor specs they are all better on the 2ls, but only slightly.
danmm7
GX - 1st Gen (2003-2009)
16
06-12-21 09:02 AM
peterls
12
06-27-14 11:46 AM
willhickey
07-27-11 07:22 PM
GSing430
Suspension and Brakes
08-17-07 01:52 PM
richonenz
07-17-07 04:30 PM
Quick Reply: gen 2 brake upgrade
