Ls400 96 fuel filter and distributor
Old 07-07-09, 06:48 AM
wqqclhtt
wqqclhtt's Avatar
Default Ls400 96 fuel filter and distributor
Hi, can anyone tell me where is the fuel filter in the LS 400 96? and What is the function of distributor cap and rotoe? Thank you very mucn!
Old 07-07-09, 07:54 AM
acidfire52
acidfire52's Avatar
The fuel filter is right under the tank, above the rear axle.
For the cap and rotor see this:
http://en.wikipedia.org/wiki/Distributor
Old 07-09-09, 09:31 AM
wqqclhtt
wqqclhtt's Avatar
Thank you acidfire52! Do you think it is necessary to replace the Distributor and rotor, and ignition wire set on my 90K 96 LS400? So far I feel everything is normal.
Old 07-10-09, 07:40 AM
acidfire52
acidfire52's Avatar
At 90k I wouldn't worry about it.
Has the 90K service been done? Timing belt and water pump are the 2 big ones.
Other than that, I would do the fluids, plugs, filters and call it good.
tyncobb
10-31-14 11:19 AM
TriniLex
10-15-07 07:19 AM
PRSUIT460
Maintenance
01-13-04 01:40 PM
GA400
Maintenance
12
07-29-02 08:54 PM
Quick Reply: Ls400 96 fuel filter and distributor
