Where is the location of the Running Light Relay?
I just bought this Running Light Relay for my 91' ls400. Its taking from a 91' ls400 from us. my car is european but i hope it fits.
I just cant find the plug. I looked almost everywhere in the engine compartment without any luck.
Hopefully i dont have to split the whole car apart. Maybe someone in here know where it is :-)
This is the picture of the relay: http://i.ebayimg.com/24/!BYI,RDwBGk~$(KGrHgoOKkUEjlLmVks,BKf5(s1pyg~~_12.JPG
Thank you.
Thank you.
If you've looked everywhere and can't find it, then it's behind and below the drivers side headlight assembly. There's a set of relays under there but I can't remember which one's they are. You'll need to remove the sidemarker and headlight/foglight assembly on that side to get access to them. If I remember correctly, there's a single phillips head screw that holds the sidemarker on, and then four 10mm bolts that hold in the headlight/foglight assembly. Removal of the correct four bolts will take it out as a single unit. In Germany, is the foglight actually a highbeam, and the fogs are down lower in the bumper?
Ok i will give it try tomorrow. Thanks :-)
Just putted clear blinkers in the front. The screws were rustet so much that i had to be violent and brake some taps and go crazy with a dremel. but it worked out and woow its really a facelift with some white lights on :-)
OrangeCrsh
08-07-05 06:47 PM
