ls400 front caliper differences
hi all,
So I've searched and searched and haven't been able to find the answer im looking for, so here goes.
I'm in the process of buying a 94 LS400. The front left caliper is sticking. Now, I've read about SC/GS guys using LS calipers as an upgrade. The thing i cannot find any info on is what year did the LS come with the 4 piston calipers? I've seen that 93-94 got an upgrade from the 90-92. Are the 4 pistons on the 93+ or just the next generation, 95-00? If its the latter, will the 95-00 rotors/calipers bolt on to my 94 (hacking away the dust shield is a given)?
if so, i have some other questions about the master cylinder.
thank you!!
thank you!!
the 95-00 is the 4 piston upgrade. it will bolt up with 2ls balljoints. i have some 2ls f/1ls r powdercoated calipers and oem 2ls front balljoints i am considering selling if you are interested.
that is true... forgot about that one. i'm just wrong all over the place today. you need wheels with proper disk clearance or spacers and possibly diameter clearance.
dwebb99
04-15-09 03:54 PM
evileagle
Suspension and Brakes
12
08-28-07 07:16 PM
