Valve Adjustment Shortcut?
Hello I have a 92 sc400 1uzfe engine that I am attempting to replace an out of spec shim that is noisy...the problem I am experiencing is that it is the no7 cylinder intake valve that is closest to the firewall...
after I position the cams at tdc is there any way of removing the timing belt off just the intake cam sprocket and keeping the belt tight with a ziptie to something (I am guessing by removing the tensioner from underneath to provide some slack) or is that just wishfull thinking...thanks for your time
I recommend that you not torment yourself, nor torment the delicate aluminum engineering, and dive in, replace idlers, water pump, belt as necessary, but get the camshafts off cleanly so you can inspect and address. Do a current valve clearance check, be precise! and you can do the bucket shim replacements then.
Colin
Thank you..I will definitely take the bucket out and check underneath as you advise due to the fact that the clearance is way out of spec and all the other intake valves were within...cheers
