Thought AC compressor was locked, now AC works but my belt is squealing
Is it at all possible that a worn belt would cause this? The belt doesn't look in rough shape. When it was warmer out the ac would turn on, engine would idle up a bit and then I'd hear a noise (light clunk) and the ac light would start to blink.
Now it's colder out and the engine idles up and AC light stays on, but as stated, it sounds like my drive belt is squeaking.
My power steering pump pulley wobbles a little bit but I wouldn't think it would be enough to cause this...
Any ideas?
Any ideas?
Yeah, I'm leaning more towards an AC problem. All the pulleys look good and tight except for the power steering one which wobbles a bit, but not enough to cause issues at the moment I don't think.
Idler pulley looks solid, fan bracket is good.
Still, no squeak with AC on, squeak with AC off.
Idler pulley would have made sense since the idle goes up when AC goes on. Either way, it's weird and annoying.
B4TM4N
04-04-10 08:18 AM
ac, accompressor, air, belt, breaks, compressor, conditioner, fan, lexus, locked, ls400, runs, squeal, squealing, works
