help asap 1994 ls400
i have used the search,but i cant really find an answer.ok i have a 1994 ls400.and somedays it starts and runs fine,sometimes it starts and the ac does not work,some days it will just crank and crank and crank,and not start.some days it will start but jerk and hesate when you try and give it gas,when you take your foot of the gas it will speed up.some days when i drive it just shuts off.plz help me with this problem>pls.
It certainly has, what with spoiled little brats hoping to be spoon-fed easy answers for problems that might actually take a little more diagnostic effort than your totally vague dispeptic reports of intermittant problems.
Tell you what: the next time the car doesn't start, try getting out of the driver's seat and go diagnose what you are missing, air/spark/fuel? If the A/C "doesn't turn on", maybe you could tell us the behavior of the A/C indicator lamp, or whether or not the compressor engages.
I can promise you this, most people get exactly the help they deserve. Perhaps when you learn to spell the exceedingly simple and phonetic word f-o-r-u-m, perhaps you will earn a little more effort from those who have to read through your petulance.
Colin (me? crabby?)
Colin (me? crabby?)
Last edited by Amskeptic; 10-09-09 at 03:46 PM. Reason: too many "perhaps" changed to "maybe"
could be many, many, many things, some of which have nothing to do with the A/C.
Knowing which of the necessary things is not happening when it won't start will help. You need fuel, spark, the right timing for the spark, and that's usually it. So if you have no spark, it will be a different solution than no fuel. How can you tell? Many ways to do so but generally can you smell fuel as you try to start it? Especially through the tailpipe? Are the plugs, wires, and coils in good working order? Etc.
Based on what we know so far, it could be a CKP, PCM, fuse, main relay, jumped timing belt, ignition coil, plug, distributor, wiring harness, and many other possibilities.
Ef8people
18
03-26-13 06:56 PM
hamburgfly
IS - 1st Gen (2001-2005)
11-10-12 03:12 AM
