Brakes shudder-98 LS400
Old 10-14-09, 05:04 PM
vuman1
vuman1's Avatar
Default Brakes shudder-98 LS400
When I apply my brakes at a speed of about 25-35, the brakes shudder as if the ABS is engaged. This did not happen until a garage changed out my bearings. Does someone know what's the problem with my car?
Old 10-14-09, 06:30 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
"warped" rotors
Old 10-15-09, 06:25 AM
acidfire52
acidfire52's Avatar
Originally Posted by PureDrifter
"warped" rotors
+1
Have your rotors turned or replaced.
Old 10-15-09, 09:46 AM
Lanson
Lanson's Avatar
You guys think this could come from a misalignment from corrosion on the rotor hat relative to the hub or wheel?
Old 10-15-09, 11:52 AM
acidfire52
acidfire52's Avatar
It could be, I would take them off, have them turned and cleaned, brush the wheel hub surface to make sure and put em back on with new pads. THEN, go out and bed them in properly.
Old 10-15-09, 03:06 PM
vuman1
vuman1's Avatar
Default Shudder Brakes
I took my car in for brakes work because they slipped when applied and seemed like they traveled too far down. I was told it was not the brakes but the bearings. After the bearings were replaced it was when the brakes shudder and appears as ABS was enaged when I braked to a complete stop from 25-35 mph.
Assuming if it is a warped rotor or something wrong with the rotor, could this have been caused by the work on the bearings, especially when none of this problem existed prior to the changing of bearings?
Thanks
Old 10-15-09, 06:19 PM
Famou$LS
Famou$LS's Avatar
more then likely your abs sensor on the bearing, check and see if they forgot to plug it in. mine does it at 10 mph while brakeing, and the lexus mechanic I got it from said I need to get a front drivers side abs wheel sensor. I think the word shutter is what is throwing people off. That word makes me think of warped rotors.
isflexus
03-18-15 07:37 PM
silver305
06-07-13 08:02 PM
JC07ES350
ES - 5th Gen (2007-2012)
12
05-07-10 07:01 PM
oblivionis
Suspension and Brakes
16
12-23-09 04:53 PM
NyceTry
IS - 1st Gen (2001-2005)
05-11-09 08:19 AM
Quick Reply: Brakes shudder-98 LS400
