Help with belt tensionor
my belt tensioner pulley is going bad and needing replacement. which way am i supposed to turn the bolt to get the pulley off?
its reversed.
my tensioner pulley broke off of my 90 ls400, when i was trying to put the serp belt back on. it wouldnt come lose.
you dont have to take pulley off to remove the tensioner. but i believe the alternator must come out. I havent gotten around to replacing it just yet. Mine was original. I believe your supposed to change it out every timing belt change.
its reversed.
it is a reverse tread....to da left tightens, to da rite loosens
ok, but dont we have to remove da belt to remove altenator. if so, how u gon do dat if da tensioner is broke and u cant get da belt off???
mine went bad yesterday, dude told me to loosen power steerin pump to loosen tension. he was a shade tree tho.
YODAONE
02-06-17 02:02 AM
