Factory finish double din head unit bracket
Old 10-19-09, 11:57 AM
Asia-H.T.
Asia-H.T.'s Avatar
Default Factory finish double din head unit bracket
Well, title says it all. I'm looking for a factory finish bracket for my '93 LS400. The one I have here has a different structure as the A/C unit. It's more rough and less shiny. don't like that.
Maybe someone knows more about this? and probably there's some way to 'treat' the bracket I already have, in order to get the same surface as the A/C unit.
I thought of sanding and polishing it, if there isn't anything available.
Your input is welcome
Old 10-21-09, 12:06 PM
JAndersson
JAndersson's Avatar
Was planning to fix the finish of the stereo bracket I ordered with help of this guide, http://www.lexusownersclub.co.uk/for...opic=46907&hl=
But when I got I decided not to because the finish was got enough for me and I was afraid I just was going to mess it up. But probably are you more skilled on this kind of work (I'm really worthless with this kind of things), so good luck. Attached a photo on my stereo install if you want to compare with your own install. The bracket is a part of 1993-1994 LEXUS LS400 DBL-DIN RADIO DASH KIT COMBO 8156.
Old 10-22-09, 01:45 PM
Asia-H.T.
Asia-H.T.'s Avatar
Thanks for your input! I'll keep this in mind when I'm going to swap my OEM head unit
ph0bolus
04-05-19 10:49 AM
fristadm
RX - 1st Gen (1999-2003)
01-05-15 08:17 AM
kuykendc
03-22-13 11:40 AM
mhsu408
01-14-06 01:20 AM
Anatoliy
02-08-03 11:31 AM
Quick Reply: Factory finish double din head unit bracket
