Need help with suspension question
Old 10-25-09, 07:09 PM
deanbrown
deanbrown's Avatar
Default Need help with suspension question
Hello all,
The joint in the attached pic (circled) is loose and I think just plain worn. What is this piece called (wishbone?), and is there a bushing in the joint or do I need a new part? Is it simple enough to change?
I noticed it just now when changing the front rotors (which you can see there nice and shiny - they are from R1Concepts, let's hope they are worth the money.)
Thanks
-Dean
96 LS400, 230K
Old 10-25-09, 09:03 PM
trukn1
NELOC Mod
trukn1's Avatar
The circled part is the upper ball joint. It is part of the upper control arm; the V-shaped part attatched to it. It cannot be changed separately; has to be done as the entire unit.
Old 10-25-09, 09:07 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
if that upper ball joint is bad, you need an entire new upper control arm, list is ~$300/side from lexus. best to replace in pairs.
Old 10-26-09, 12:01 AM
deanbrown
deanbrown's Avatar
Thank you both. I just ordered one (d/s, $130, there are a few to choose from on ebay).
Cheers,
-Dean
ps this one is pretty shot - is there some danger if this thing pops while driving or cornering?
SNiiP3R
02-26-20 10:31 AM
rob22
07-17-09 07:39 AM
acidstorm
Suspension and Brakes
14
01-04-09 09:01 AM
work1
05-27-05 10:58 AM
dbullen
08-04-03 07:41 AM
Quick Reply: Need help with suspension question
