New 1997 LS400 Coach Edition
Old 10-27-09, 07:11 PM
seanl
seanl's Avatar
Default New 1997 LS400 Coach Edition
Ok, I managed to get a few decent pics of my Opal Pearl '97 LS400 Coach with the bo-ring '02 LS430 wheels. Yes I know 16s are so 1990s but this car is just my daily driver and I here in downtown SF I'm going to stick with the tall sidewalls for now.
I also removed all the corroded gold badging and replaced with chrome. I considered doing the black pearl thing but I was too lazy.
Last week I had the leaking power steering pump replaced and also had the worn strut rod bushings changed at the same time. No more LS clunking!!!
The only things left that need attention are the lower ball joints and the brakes are going to need pads soon. Given the the car has 100K on the factory rotors (surfaced once) I was thinking about just buying new front rotors from Carson Toyota and changing them out with the pads. My previous LS400 had warped front rotors somewhere in the 90K range. I'll probably have my local indy Lexus shop do the ball joints and I'll swap the brakes out in a friend's driveway.
Attached Thumbnails New 1997 LS400 Coach Edition-ls400-ce-3.jpg   New 1997 LS400 Coach Edition-ls400-ce-2.jpg   New 1997 LS400 Coach Edition-ls400-ce-1.jpg
Old 10-27-09, 07:14 PM
Thermactor
Thermactor's Avatar
The ball joints are an easy DIY! All you need is the "tie rod end puller" with the jaw from Advance Auto Parts or AutoZone to complete the task. I really like your car, it looks awesome. Congrats on the purchase.
Old 10-27-09, 07:30 PM
97CE LS400
97CE LS400's Avatar
beautiful color
I thought the Coach Editions came with Special Champaign Pearl Badging? At least mine did.
Mine is a daily work driver as well....but is kept in the garage while at rest.
Old 10-27-09, 07:37 PM
steveski
steveski's Avatar
Nice LS - lower BJ's are an easy change. I used a pitman arm puller from AutoZone. You can rent it for free - no brainer for DYI projects. I had the same wheels on my LS once - nice upgrade
Old 10-27-09, 08:21 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
he needs the pitman arm puller.
the tie rod puller isnt big enough
Old 10-27-09, 10:36 PM
seanl
seanl's Avatar
Smile
Originally Posted by 97CE LS400
beautiful color
At first I wasn't sure if it were a real Coach, as it didn't have the champagne emblems and Coach logo. Sure enough the original owner must have had poor taste to remove the original emblems and replace with a "Gold Package". Ditto for the Coach painted wheels. The chrome afterrmarket wheels with gold Lexus logos were awful. But the perf. seats, coach branded arm rest, floor mats, shift **** are Coach correct and there is a mint condition painted 5 slot "Coach" wheel in the spare tire well.
Thanks for advice in the lower BJs. I'll consider DIY. Deffo on the brakes, they're easy. Worst part replacing the front brakes in the past was loosening the stuck set screw that kept the rotor flush on the hub. Needed an inpact screwdriver to break it loose. Which of course I don't have access too as it's in storage with most of my tools while I enjoy urban living in downtown SF.
Old 10-28-09, 05:12 AM
Thermactor
Thermactor's Avatar
Thanks. I thought it might be the pitman arm puller. Buy it for $9.99 or rent for free! Whee!
kings222
IS F (2008-2014)
30
04-19-23 01:00 PM
Sherl
17
07-04-19 09:46 AM
stk7741
07-25-11 06:51 AM
Quick Reply: New 1997 LS400 Coach Edition
