Leakage
Leakage
I have recently purchased a 92 LS400- awsome car!, but I have a couple of issues the first is that the sun roof leaked a bit when i took it through the car wash, not when it rains, I suspect this is due to a cloged drain hose but I dont know where to find it to un clog it. I also have a problem with water leaking out from under the passanger side dash, again I suspect this is due to a cloged drain hose but do not know where to look. Any help with these issues would be greatly appreciated.
Hi,
If you check posts for sunroof leaking there is a tutorial on how to clean them. On the leak in the pass floor, there is a drain hose for condensation leaking out. You can see it from under the engine compartment at the firewall. Usually bugs crawl up and die, or a spider will web it closed. Canned air will clean it out.
Good Luck,
Fblonk
Good Luck,
Fblonk
whokidd
11-19-13 12:45 PM
