please reply quick! new battery needed
Old 11-04-09, 01:32 PM
jbreezy27
Registered User
jbreezy27's Avatar
Unhappy please reply quick! new battery needed
i need a new battery and im getting one today. is there a certain brand or type of battery that will last long with subs hooked to it? i have a 1000 watt amp connected now and i think i need a stronger battery? help!
Old 11-04-09, 01:42 PM
curepunx
curepunx's Avatar
Generally, as long as you're not running more than 1000-1500 watts "RMS", then a good battery and 4 AWG amplifier kit will suffice. If you want a good battery, then go with the (more expensive than typical) Optima Battery. They run about 175-200 at Kragen and Autozone.
Also, make sure your cable terminals are in good condition!
Cheers
Old 11-04-09, 01:54 PM
jbreezy27
Registered User
jbreezy27's Avatar
yea im definately going with a more top dollar battery, just had a new alternator put in a couple months ago so mite as well just top it off and be good to go for a bit.
thanks
Old 11-06-09, 06:57 PM
nuron
nuron's Avatar
Die Hard or Insterstate are great brands to look at. Very reliable and durable.
Old 11-06-09, 07:13 PM
toantran99
toantran99's Avatar
I would add one of those capacitor to your amp. The big one that are suppose supply extra juice when the music has a "loud" boom or bass to it.
Old 11-06-09, 07:16 PM
3UZFTE
3UZFTE's Avatar
It doesn't matter, their all the same, unless you spend some good bucks. If you really have a nice sound system, spending money on a good battery shouldn't be a problem.
Old 11-06-09, 10:56 PM
jbreezy27
Registered User
jbreezy27's Avatar
i got a die cast yellow top w/ 960 cca
i should be set for awhile
Old 11-08-09, 08:51 PM
Mr.Euro
Mr.Euro's Avatar
got a red top with 910cca. it holds up to my system. mine is i think 1350rms/2600peak on the amp and 2650rms/5500peak on the sub. so its a good amount.
Measured
Canada
12-16-12 07:25 PM
shikbas
02-03-10 05:00 AM
genijet
09-28-08 01:46 AM
hammer
Maintenance
10-28-03 06:44 AM
Dazz5627
03-04-01 11:20 AM
Quick Reply: please reply quick! new battery needed
