What is 'EGR' in Lexus terminology?
It should def. be an EGR Valve. That's what is stated for an OEM part.
EGR VALVE
LS400 2562050030 $ 324.40
The tube is what usually rusts to death though.
Important to mention, that the EGR tube is mis-represented in the tech book. They say you have to remove the cyl head but you don't. You pull the exhaust and crossmember, and the trans needs to slip down a bit with some force via a prybar or some heavy wood. Then there's enough room to reach the EGR. People say it takes 3hrs.
EGR VALVE
