If normal, where does your temperature gauge needle read?
Old 05-22-24, 08:34 PM
  #31
Stroock639
Stroock639's Avatar
Originally Posted by NewRoLex
mine sits just above the middle is that normal. Just changed the thermostat with oem one from lexus. Thanks in advance.
might be awhile before they respond lol but that's not normal, should sit just below the middle right above that 2nd tick mark from the bottom
if you haven't yet let the heat run on FULL for awhile since it sounds like your coolant may not be bled properly, check the reservoir before and after to see if the level drops a bit (it should)
Old 05-22-24, 08:52 PM
  #32
400fanboy
400fanboy's Avatar
Can confirm, it should be just above the 2nd tick mark. And it should never move, if it ever moves something is wrong.
Old 05-24-24, 12:31 AM
  #33
shahnoctis
5th Gear
shahnoctis's Avatar
Mine sits a little between the 2nd and 3rd mark with only slight movement on hard acceleration
jennypenny
04-03-19 10:30 PM
jewelerz
30
01-21-18 09:20 AM
SC3coupe
GX - 1st Gen (2004-2009)
11-11-15 02:31 PM
MValentine
09-07-13 02:10 AM
Rasimmo
12
05-07-13 07:54 PM
Quick Reply: If normal, where does your temperature gauge needle read?
