so its said...
Old 11-18-09, 07:44 PM
dsabc2867
dsabc2867's Avatar
Question so its said...
so its been told to me that if i flush the transmission and change the fluid in it that the possibilty of the transmission breaking is very good. one guy has even said that the transmission will go into "shock". this guy made it sound like my car has a central nervous system. but im no mechanic and i really dont know anything about this stuff. so can so someone tell me if this true. and one more thing. has anyone ever installed a rebuilt torque converter from lextreme? thank you guys for any information that you might provide.
Old 11-18-09, 08:56 PM
valex
valex's Avatar
What many members do is drain whatever comes out - approx.2 qts (I have a 1999 LS) and refill with the same amount of new Toyota IV ATF every oil change. This way you keep your fluid clean without dropping the pan. A Toyota tech and some members here said that opening transmission could creat problems and you could do more harm than good. I don`t know how true all that is, but I just followed the advice and have been doing drain/refill 2 qts.
Old 11-18-09, 09:18 PM
AceVA
AceVA's Avatar
There's a difference between doing a flush and fluid exchange. With a FLUSH and a high mileage transmission that has not been cared for, there is a chance that contaminants could be dislodged and cause the transmission to fail.
A fluid exchange (this does not add any pressure and simply passes the old fluid through a unit and new fluid is put in its place) is safe and the only way to get all fluid out.
Ask the facility what type of equipment they use.
Old 11-18-09, 09:50 PM
thebeeguy
thebeeguy's Avatar
Great advice.
At my shop we've been using a Wynn's fluid exchanger for years and have never had a problem.
I HATE when people tell you not to change your fluid because it might damage the transmission. Well if you DON'T change the fluid when its dirty/burnt/old, guess what, it'll damage your transmission too. (this is not directed at you AceVA, I'm saying in general)
If your fluid is dirty, change it. If your fluid is due by mileage, change it. If you want more insurance, hell, drop the pan and change the filter, it's not going to hurt. Chances are if your car is old, your transmission pan gasket will be leaking and need to be replaced anyways, the filter kits come with a new gasket.
Just be sure you use the correct fluid type and you'll be fine... And yes, don't "power flush" it, do a fluid exchange. Some places have a nasty habit of just doing a "drain and fill" where they just drain the trans, put the plug back on, fill it up and send you on your way. That only empties out a fraction of the fluid thats in your transmission. IF they HAVE to do a "drain and fill", they should at least do it over and over again until they get most of the dirty fluid out... But if that's the case, find a shop with an exchange machine, it'll just give you more peace of mind.
Old 11-19-09, 04:47 AM
Schnitz
Schnitz's Avatar
Originally Posted by dsabc2867
..... has anyone ever installed a rebuilt torque converter from lextreme?
I am curious as well.
Old 12-09-09, 02:54 PM
dsabc2867
dsabc2867's Avatar
i take it that no one has bought and installed a rebiult torque converter from lextreme. I was just wondering what kinda personal experiances anyone may have had with this product. thanks for any advice that you might provide.
Old 12-09-09, 03:22 PM
vaughn37
vaughn37's Avatar
i found this place..they have transmissions and converters
http://www.levelten.com/SearchResults.asp?Search=a340
Old 12-09-09, 05:26 PM
Amskeptic
Amskeptic's Avatar
I have had other purchase experience with Lextreme, and found it satisfactory.
Colin
Old 12-09-09, 05:56 PM
dsabc2867
dsabc2867's Avatar
what have you purchased from lextreme
dicer
34
11-18-15 09:34 AM
mmatheny
05-05-09 02:11 PM
Limca3
Maintenance
04-19-03 08:39 AM
BananaGS
07-04-01 10:15 AM
Quick Reply: so its said...
