2000 LS400 alternator replacement
Old 12-03-09, 08:32 AM
McSwine
McSwine's Avatar
Default 2000 LS400 alternator replacement
Title pretty says it all...how difficult a job is this? It appears the dealer is going to want $600+ and I would just as soon not spend that much if I don't have to.
I've done a search and found a lot on the previous model, but can't find much on the 1998-2000's. Is this something I should have sense enough to do myself (moderate mechanical ability), or do I suck it up and get bent over by the dealer?
Any comments/suggestions would be welcome.
Old 12-03-09, 09:52 AM
etex
etex's Avatar
A rebuilt (Denso) alternator is approximately $250 and labor (not at the Dealer) is about $50... at least less than $100. Sounds like you could do it yourself if you find a link on here and follow directions. Good luck.
Old 12-03-09, 09:54 AM
McSwine
McSwine's Avatar
Yeah, I found an alternator at O'Reillys with a lifetime warranty for $215...at first I was thinking dealer all the way, but damn...$380 is a little steep (part only).
If anyone has any knowledge on this, please feel free to chime in.
Old 12-03-09, 02:07 PM
vaughn37
vaughn37's Avatar
i just bought one of these.and it is working....has a 1 year warranty http://cgi.ebay.com/ebaymotors/LEXUS...Q5fAccessories
Old 12-03-09, 05:41 PM
Thermactor
Thermactor's Avatar
If you can't do the alternator yourself you should get your *** beaten
Old 12-03-09, 06:54 PM
Lexozz
Lexozz's Avatar
DIY all the way! I just got mine done a few months ago, I got stuck in west bubba-f%$ and had to let the local mechanic do it for parts and labor $300.00 with a lifetime warranty. I would have done it myself if had my tools and a good jack. Job took 20 minutes from the bottom, the mech took the power steering pulley off for easier access.
Old 12-03-09, 07:27 PM
valex
valex's Avatar
Default 1999 Ls400 alternator
I have a 1999 Ls400 with 110K miles. I changes my alternator 2 months ago. I have limited mechanical skills, but I read here on forum that it shouldn`t be hard at all. I did it in like 1,5 h(I was taking my time though). Like someone said here on a forum, it is a very tight fit and it`s like your car having a baby You work from underneath the car and wiggle the alternator to make it come down. I also had to remove a pulley to have access to one of the bolts. I bought mine new from Carson Toyota $367.38 AND I mailed the core back and got a $30 refund. I heard many people don`t recommend using non-Lexus electrical parts, that`s why I bough a new OEM.
Hope this helps,
Val
Old 12-03-09, 08:23 PM
McSwine
McSwine's Avatar
That made me snicker. I'll be be first to admit I could use a good *** kicking.
Thanks for all the replies.
Old 12-04-09, 12:25 AM
skperformance
skperformance's Avatar
It is not the easiest to replace because the pulley does need to be removed on teh power steering (?) pump to slide it off the main bolt mounts.
1.5 is amazingly fast for a novice.
Old 12-04-09, 12:32 PM
Amskeptic
Amskeptic's Avatar
I removed three 14mm bolts and one 14mm nut on the P/S pump and just slid it forward a few inches. I am not going to get tough on the precision moving parts of the P/S pump trying to break the pulley loose. Leak-free at 105 k miles.
Old 12-11-09, 08:02 PM
solok25
solok25's Avatar
Exclamation
wowww!!! really i just got a rebuild all oem internal but higher output 220AMPS!! from the "BAY" for 200$ shipped something to think about when you consider a high end system and hell even if not its still cheaper and higheroutput soOOO do the math save save save!
Old 12-12-09, 02:25 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
except most ebay alternators ive seen go bad within a year or just outside of the "warranty"
Old 12-12-09, 11:45 AM
Garage7RP
Garage7RP's Avatar
I changed my alternator without removing any pulley. I removed the alternator from the bottom.
Old 12-13-09, 04:34 PM
solok25
solok25's Avatar
Well i hope the one i got lasts ! Ive had it for a 2week just been way tooo cold and plus i wanted to check around and see what other people got to say on the install. so i think i got it ..its getting warmer so tomorrow i will tackle the job. try and take some pics im also installing an additional 4g power line fused w a 250a. wish me luck i will post results w pics if i can figure the upload part (im nwe btw) anyways
Old 12-14-09, 11:28 PM
trukn1
NELOC Mod
trukn1's Avatar
Wouldn't quite say that. I bought an "EBAY" alternator a few years back for my 92; was performing flawlessly. It died a pre-mature death due to me not fixing the power steering leak, so it literally drowned in the car's own fluids.
I have changed my alternator out on my 92 a few times and have pretty much gotten it down to about 45 minutes from start to finish. Hardest part is trying to get the belt lined back up correctly over all of the pulleys. The tensioner only givers but so much so it takes me a lil while to remember the trick to it. Not sure if the later UZ engines are much different from mine, but it is completely do-able.
OMAHA
09-28-18 11:30 AM
johno101
12-27-15 06:29 PM
MCCR
11-22-13 01:46 PM
alexamparo
Maintenance
10-10-02 03:49 PM
Quick Reply: 2000 LS400 alternator replacement
