rear springs
rear springs
Hey guys i was wondering is there a way to beef up my rear springs with my audio and full tank of gas my car sags real bad the struts seem to be find but springs seem tired is there a coil spacer or something out there?
when i bought my rims and still had my stock blown sus, the rim shop put some hard rubber or polyurethane dampeners in between the spring to stiffen them up,
not the same shape as the one my rims shop used but by the looks of it, its the same thing http://cgi.ebay.com/ebaymotors/Energ...item1c030f69d6
are those 20s or 22s on ur car in that avatar pic?
Check out these rubber spring inserts also. I have been using them. You get 15-20lbs. of increased spring rate.
http://www.jegs.com/i/Mr.%20Gasket/7...0002/-1?CT=999
I was using them in both front and rear to prevent sag. Since I am dropped more than 1" I needed to increase spring rate. It is a long story and I won't bore you with details. These are inexpensive and easy to install.
DJ SprinklesNJO
09-25-08 12:34 AM
