Car won't turn over or crank
Old 12-05-09, 05:56 PM
kimanh
kimanh's Avatar
Default Car won't turn over or crank
so i left my car out for a few days and we had a big windy snow storm yesterday. so in the morring i decide to take the lexus ands car won't start, it doesn;t make any clicking sound or nothing. i open the hood and i see snow everywhere on the intercooler,fan, pretty much everything by thier was fill with snow. so i check teh battery and everything seems to work, radio, headlight, blows air through the vent, remote key to open and lock door works, alarm is still active. VSC light is also on.
its 2000 ls 400 with only 60 miles, anyone know what it can be ? can it still be the battery even tho everything electrical works?
if anyone wondering how bad teh snow storm was too get snow all over my fan and intercooler area, here a few pics.
Old 12-05-09, 06:58 PM
trukn1
NELOC Mod
trukn1's Avatar
60 miles on a 2K LS?? Is this a typo?
Anyway,,check your battery connection to make sure that everything is tight. By the looks of your pic, that aint a snowstorm,, that is a downright avalanche. LOL!! Is possible that you may have fluid freeze with all of the snow getting in those areas and you may need to spend some time thawing the car out. You say everything electrical still works; are your headlights really bright or just kinda dim. Is possible also that your battery may be drained under it's cold cranking amperage in order to start the car. I would take the easiest route first, remove the battery and have it tested/charged and then start from there.
Old 12-05-09, 07:17 PM
LiCelsior
Retired
LiCelsior's Avatar
yep def sounds like the batt droppped below the appropriate cranking voltage...mine does that if i dont drive it for like 2 days...gotta change that out for a optima.
Old 12-06-09, 06:33 PM
kimanh
kimanh's Avatar
opps, i mean 60,000 miles.. i'll take out teh battery tm and test it.
Old 12-06-09, 06:54 PM
Och
Och's Avatar
Holy crap dude thats a lot of snow. Global warming hard at work.
Check your fuses and relays I guess.
Old 12-06-09, 06:55 PM
Och
Och's Avatar
By the way, I assume by intercooler you mean radiator?
Old 12-06-09, 09:49 PM
dashan
dashan's Avatar
how is the RWD LS400 driving in that weather?
I am moving back to New England and I am worried about whether my LS400 RWD is drivable in snows in the winter.
Old 12-06-09, 09:56 PM
LiCelsior
Retired
LiCelsior's Avatar
snow tires are a must in heavy snowed areas.
Old 12-06-09, 10:01 PM
JAndersson
JAndersson's Avatar
Default Driving in snow
As long as your car has traction control (TRC) it's no problem at all. You just have to be a little more cautious when doing a overtaking.
Old 12-07-09, 12:52 PM
kimanh
kimanh's Avatar
yah i mean radiator, i tested battery it was no good, so i bought a new one and still no good, when i try to start it just dead silent. what fuses do i check and where is the relay located? taking teh battery off in the cold weather sucks.
dashan - it drives great as long u have a good set of winter tires and traction controal on and drive carefully, unless u get snow like we did and no one was going anywhere. snow was to high in all the residential area and some area was just impossible for smaller cars.
anyways another suggestion before i get it towed to a shop.
Old 12-07-09, 01:16 PM
curepunx
curepunx's Avatar
Well if the case of the battery was already checked...then the next thing i would do is....check all the ground cables. It seems that theres no power being transferred from the battery itself so there's something not connecting properly. Try checking your ground cables/distributors/spark cables, especially the ignition coils...i know ive had that problem where even by the slightest slipping, the car would not turn on at all....
Old 12-07-09, 07:39 PM
kimanh
kimanh's Avatar
are all these found in the engine bay? u have any digram or pictures of these things?
thanks
Old 12-07-09, 07:43 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
thanks
...i think you need a mechanic.....
Old 12-07-09, 08:43 PM
Garage7RP
Garage7RP's Avatar
Does your car have an alarm?
Old 12-08-09, 12:25 PM
kimanh
kimanh's Avatar
yah i think so too but ima try to it my self 1st if all fails then ima get it towed to a shop.
Garage7RP - yah factory alarm.
Quick Reply: Car won't turn over or crank
