how wide can i go with tires?
Old 12-09-09, 10:38 AM
2000 ls400
2000 ls400's Avatar
Default how wide can i go with tires?
i have a 2000 ls400. it has the stock 16" rims. i am keeping the rims, but want to put the widest tires possible without rubbing. stock is 225/60/16. also i might put spacers on, any suggestions? thanks
Old 12-09-09, 10:40 AM
LiCelsior
Retired
LiCelsior's Avatar
i think the width of the stock 16s are 7"..u can get away with 245s but thats about as much as i would go...255s are gonna look stoopid.
Old 12-09-09, 11:45 AM
jasonm
jasonm's Avatar
If you arent doing any other modification, it makes no sense. The car is engineered to work best with the 225/60/16. You may want to look at changing the quality of the rubber.
Old 12-09-09, 12:46 PM
LiCelsior
Retired
LiCelsior's Avatar
they do make 225/60/16 KDWs.....id pick some up if i wanted some UHP summer tires.
Old 12-09-09, 01:05 PM
Kansas
Kansas's Avatar
I think the Toyo Proxes T1R in 245/55-16 may be the only "plus zero" substitute available for the OEM 225/60-16 tires for use on OEM 16" wheels on the LS400 that keeps the speedometer accurate. Toyo advertisements in car magazines in the mid/late 1990s used to show them on LS400's.
Old 12-09-09, 01:27 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
plus anything wider is going to be ballooned to hell on the stock width rims.
Old 12-12-09, 04:25 PM
2000 ls400
2000 ls400's Avatar
thanks for all the info. what about spacers?
flip33
04-30-12 10:42 PM
Moohamp
11-24-11 11:47 AM
marcman18
IS - 1st Gen (2001-2005)
06-13-06 10:39 AM
JCW
Wheels, Tires & Brakes Forum
03-05-06 06:39 PM
1LS400Lexus1
07-16-04 06:59 PM
Quick Reply: how wide can i go with tires?
