LS400 Replacing Turn Signal Bulb - How to?
Any advise on replacing the front turn signal bulb besides taking to the shop? Appears the front head and fog ligh need to be removed to gain access. Fog lite comes out with a few screw removals but do not see how to remove head lamp.
The parking lamp assembly should have one little phillips screw up top that you remove, then you pull the assembly forward out diagonally from the car. There are two little plastic tabs that hook the rear of the assembly at the fender. Then you can just twist and remove the light and replace the bulb.
hth,
Colin
For future reference,, your cars year will aid us with diagnosing your problem and giving you information. On your 94, the turn signal bulbs are located in the bumper. I think you are referring to the side markers, and the advise given in the reply above will help you change the bulb. Also,, use this as a guide,,
www.lexls.com
www.lexls.com
OMAHA
03-13-14 12:10 PM
ChrisTapia
10-20-06 03:38 PM
