New member, Need help no power.
Ok i just picked up a 94 ls400 with 90,000 on the car but there is a issue with it. It has no power at all if i press the gas in it just boggs down with cel on. So i did some research on this site and it sounded like maybe i had clogged cats so i just gutted all 3 of them but nothing ,then i tried to pull some codes from the ecu and it would not work.
So i cleared the ecu by doing the pulling of the egi fuse and it drove fine idle was a little low but power was back 100% but after it warmed up for about 15-20 min it died and then i turned it back on and cel is on and no power again. So any help have you guys had this issue before and if so what was it? I am going to try to find a ecu to so if that helps. Thanks guys for any help.
yes that is what i used i found it on this site i searched before i posted this. I am going to try and switch out the ecu o2 censer and the coils and see if that works. But any other help would be great.
Yes like i said i tried to get a code but it would no flash just stay on. I put the wire in te1 and e1 put car in neutral and turned of a/c and nothing . The car does seem like it is in limp mode and from what i gathered is a o2 can cause that but that does not tell me why i cant pull a code.
Plus in closed loop mode after i reset the ecu the car drove great so if it was a coil,spark wires or plugs you would think it would misfire or have some other issue .
once Trukn1 chimes in, he'll tell you lol, he had the same problem and it was the coil.
