driver side door jammed!!!
the car was never in an accident. some kid locked the door with keys inside and tried to slimjim it. the door got stuck that way. but somehow i opened it from inside jus like that!!!
If you can get it open again its pretty easy to get the door panel off. I would inspect the operation of all of the latches. Might be a pretty cheap fix.
Lexls.com, try here under tutorial section.
I would not wait to fix this. Something is probably not connected properly connected inside the and if the door will not open again you will have big problems getting the door panel off to fix it.
jcastaneda
02-21-11 08:44 AM
